586,692 active members*
3,058 visitors online*
    Jul 2007
    82
    Joint for ATS chuck
    I need to use two 3J collet chucks (true length made by ATS) to make a part. Unfortunately the one I pull out from another Nakamura has different joint(element to connect chucks body with the draw tube). Is it possible to buy one somewhere or I need someone to make it for me. Thank You for any answer.
    Jan 2007
    1389
    ats whould be able to supply the spindle tube adapter for your machine to there collet chuck, or you can make one its very easy.
    for the most part you need to give them the machine modle number as most of the collet nose makers will know the spindle tube thread size and length needed.
    if you have to make one you will have to measure the thread on the spindle tube.
    as far as the length bolt to nose to the machine and use a pair of calipers, you can be with in a 1/8 of an inch or even more. tolorance isnt that important.
    on a new machine I always make the spindle tube part first then thread it onto the machine bolt the nose to the machine and check the distance to the face. then cut face of necc.
  1. Looking for locking ball joint!
    By tjb1 in forum Want To Buy...Need help!
    Last Post: 10-26-2010, 12:25 AM
  2. How do you connect 8020 in a T-joint?
    By pswayze in forum DIY CNC Router Table Machines
    Last Post: 05-30-2010, 06:17 PM
  3. Joint following error
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 04-11-2008, 03:02 PM
  4. Intersting robotic joint
    By Zathras in forum Mechanical Calculations/Engineering Design
    Last Post: 10-07-2005, 07:05 PM
