586,105 active members*
3,248 visitors online*
    Jan 2004
    539
    New VM2 with TPC Questions
    Hello boys and girls! New machine flew in yesterday
    So a question has come up about separate power for 1000 psi TSC. There is a plug and receptacle that are sooooo close..but no cigar. Checking now but has anybody landed one of these lately?
    Gary
    Edit..not sure what TPC is...but I typed it:-(
    Oct 2009
    192
    So when you say close but no cigar - you are saying that the plug in picture two does not fit into the 'aux' socket on the left of the photo? That is where it plugs in - might be a bit tight - but thats where it plugs in. Depending how the pump is wired up - you may also need a seperate power supply to run the pump.
    Hope this helps.
    Jan 2004
    539
    Thanks for the reply. Yes one of the spades is just a little wider than the female plug. :nono:
    But the service boys found a pdf that they are going to send, but it (1000psi) needs a separate power supply. Had I known that (three months ago) I would have had that already done..:tired:
    Gary
    Aug 2010
    579
    We have seen a few problems with the female plugs where the contacts have been pushed together so that the male plug does not fit.
    Observing all safety precautions necessary use a small screwdriver to spread the contacts apart.
    Ken Foulks
    Jan 2004
    539
    Ken,
    Thanks for the reply. I am up and running as of yesterday afternoon. There is a female plug for the high pressure coolant on the side of the machine..right next to the standard coolant female plug.
    But it only controls the on and off for the high pressure pump through the control.
    The power for high pressure pump is a separate "customer supplied" plug.
    I think that is where the initial confusion began.
    No problems now..and am going to run some parts this afternoon for a trial.
    God I love these new door locks..:bs:
    Gary
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
  3. MB3 VMC-anyone have one? Questions
    By underdog in forum HURCO
    Last Post: 09-08-2010, 09:36 PM
  4. IH CNC Questions
    By krymis in forum Charter Oak Automation Support Forum
    Last Post: 10-26-2006, 04:49 PM
  5. Hello everyone, I got some Questions..
    By Buick455 in forum DIY CNC Router Table Machines
    Last Post: 04-10-2005, 04:15 PM
