586,617 active members*
2,561 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Weird Question 'bout Gage Pins and Thru Holes
Results 1 to 12 of 12
    Jul 2010
    174
    I drilled about a 2" through hole with a brand new replacable carbide tip drill. The tip is .476. I can slip a .472 gage pin (all I need) in either end of the hole and slide it through most of the way from either side. But I can't slide it all the way through from either side. Drill tip looks OK.
    So...my theory is what's happening is the same sort of thing that happens when you wring gage blocks together.
    1. Air pressure from the surrounding environment is locking the pin up in the center of the hole as the air between the pin and the through hole is squeezed out.
    2. Surface tension from coolant or water vapor is "gluing" the pin and the surface of the hole together.
    3. When two very flat surfaces are brought into such close contact with each other, an interchange of electrons between the atoms of the seperate surfaces creates an attractive molecular force.
    Got all those from a Starrett web page about gage blocks months ago.
    I had to rule out the theory that my drill is drilling larger on both ends and smaller in the center for obvious reasons.
    Anyone ever experience this weird behavior before?
    I'm drilling cast, and the drill has high pressure through coolant.
    Mar 2008
    240
    It's not a bored hole but a drilled hole and your drill is walking. You have a slightly curved hole.
    Jul 2010
    174
    Hmm...my part is being held by the A axis (sub chuck) of a turn/mill, and I'm drilling it with a live tool in the X axis. I wonder if maybe the part is "walking" (moving slightly). The chuck is holding the front, and I'm drilling through a couple of bosses in the back which are just sort of hanging out in space.
    I can't really seem to wrap my head around the curved hole concept.
    May 2004
    4519
    Drill walk, yes.
    Drills also tend to drill triangular shaped holes. Something I teach in machining class. So, even though it measures correctly across the diameter, if you check it with a tri-mic, it will be on size at one point and 60 degrees from that it will be smaller.
    The way to fix this phenomena is to follow up with a ream or bore it.
    Jul 2010
    174
    Thanks for the replys.
    What I don't get is why the problem is more pronounced on this set up then on the last, identical setup. Only thing I changed was the was the drill tip. Wonder if that could be a factor?
    May 2004
    4519
    Drill tip. Hardness, or lack of it, of the material. The way the sun was shining through the window that day.
    Jul 2010
    174
    In other words...ream it or bore it.
    May 2004
    4519
    Yes. That or put some nice drapes over the window. LOL
    Jul 2010
    174
    Thanks for the help. 'Course the upside of all this is at least it wasn't anything as evil as a case of attractive molecular force! Phew!!!!
    Apr 2006
    3206
    Some people might wonder if there isn't some spring from clamping force (even with cast), anomalies in the material that cause the drill to want to wander, ..... some people.
    Me? I'll check all that stuff,,, but after I make sure I'm wearing a clean shirt, the shop radio isn't playing rap or opera, and it's not a month that ends with an "r". And I didn't have tuna for lunch.
    Flip the part around and measure concentricity of the exit side of the part in a lathe...that's where you'll see if you've got a Wander-Drill.
    Jul 2010
    174
    I slowed my feed and took a smaller peck. No more wander drill.
    May 2004
    4519
    Cha ching! Now you are in the money.
  1. Maybe a weird question
    By vincenttor in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-21-2011, 10:22 AM
  2. Question bout feed rates
    By MynamesKenny19 in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2010, 03:46 PM
  3. FARO Gage or Gage Plus
    By SCmach2010 in forum Want To Buy...Need help!
    Last Post: 03-22-2010, 12:19 PM
  4. Question on pins. IDC vs DB25
    By TravisR100 in forum Xylotex
    Last Post: 02-09-2007, 10:11 PM
  5. Beginner Question - Punching Holes
    By lostbaka in forum MetalWork Discussion
    Last Post: 01-23-2007, 06:32 AM
