586,089 active members*
3,877 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OTC, Change display from INCH/Min to INCH/Rev?
    Apr 2004
    353
    Is there a parameter on a Fanuc O-TC that will let me change on the Program Check screen where it says "ACT.F ##.## INCH/M" to read Inch/Revolution?
    Aug 2011
    2517
    the ACT.F reading is set at 'per minute' and can't be changed. That's one of the things you don't get with the cheaper 0-series controls. On 15/16/18 there is another item that shows actual feed/rev when the feed rate override knob is changed plus or minus.
    The cheaper controls show FEED/REV but it's only the programmed feed rate. If you override it the ACT.F changes (which of course is not helpful because it's feed/minute) but FEED/REV stays the same as per the programmed feed rate.
    I believe this is the same for 21-series as well.
    In any case, it's simple to work it out from your programmed feed rate. work out 10% of your programmed feed rate and multiply it by how many 10-percents you increased or decreased and add/subtract to your programmed feed rate.
    example: programmed feed is 0.012 and over ride is + 20%
    0.012 / 10 = 0.0012 (i.e. move decimal point one place to the left)
    0.0012 * 2 = 0.0024
    0.0024 + 0.012
    = 0.0144
    Doing it this way these calcs can be done in your head, no calculator is required.
    Then simply update your program with this feed rate
    Feb 2009
    in/min to in/rev
    You can change the display on 0i 18i 21i and 32i controls by changing parameter 3191 bit 5 and 3107 bit 3 both to a 1.
    Aug 2011
    2517
    Ah yes good catch! But not all of the manuals for each model have the information listed. That's why I initially said it wasn't possible.
    But researching it further.....
    In my 21i-A manual there is no listing for parameter 3191 and 3107 bit 3 is blank (undocumented)
    However in my 21i-B manual parameter 3191 is indeed the correct parameter but it is listed as bit 0
    3191 Bit 0 (FPS)
    The unit function (feed per revolution) for actual cutting feedrate display
    displays numerals of:
    0 : Feedrate per minute.
    1 : Feedrate per spindle revolution.
    In the same manual the description of bit 3 of parameter 3107 is blank (undocumented)
    This may also apply....
    3116 Bit 4 (FOV)
    In the field of specified feedrate F on the program check screen,
    0 : The specified feedrate is displayed.
    1 : (Specified feedrate) x (override) is displayed.
    In my 0i-D manual 3191 bit 0 is undocumented.
    In my 0i-C manual it says......
    3191 Bit 0 (FPS)
    The unit of values in the display of actual speeds in feed per
    revolution mode is:
    1 : Feedrate per spindle rotation.
    This parameter is valid when bit 3 (REV) of parameter No. 3107 is set
    to 1.
    In the same manual.....
    3107 Bit 3 (REV)
    The actual speed in feed per revolution mode is displayed in:
    0 : MM/MIN or INCH/MIN.
    1 : MM/REV or INCH/REV.
    I think possibly 3191 bit 0 and 3116 bit 4 and 3107 bit 3 all need to be set to '1' to solve the 'Actual Feedrate' display problem.
    Aug 2011
    2517
    a quick update on this....
    it doesn't work. it may work for some machines depending on system software revision but on my 21i-TA even with all 3 parameters set to 1 it doesn't do anything.
  1. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  2. change inch welding measures to metric
    By juha in forum Welding Brazing Soldering Sealing
    Last Post: 06-17-2008, 02:48 PM
  3. change inch welding measures to metric
    By juha in forum Education - Teachers and Students Hangout
    Last Post: 06-17-2008, 04:20 AM
  4. change mm to inch
    By valpo48 in forum Community Club House
    Last Post: 08-24-2007, 04:18 PM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
