I am just starting a project to build a mobile base for my J-head Bridgeport and though I would start a build thread. Best I can figure the BP ways in just north of 2200 lbs is quite difficult to move around even on roller rods. The BP had been sitting in the middle of the shop getting converted to CNC but now needs to be moved to a new location. Not only will the mobile base allow me to move the mill around it will raised the base up about 3-1/2" to accommodate the new longer ball screw I recently added on the knee drive.
Initially I was going to put a wheel on each side of the base at the center of balance but I found the balance range was only about an 2 inches so I changed the design to use three wheels. It will have a castering wheel in the center rear and two non-castering wheels up towards the front of the base on either side. All the wheels will extend and retract by hydraulics using a base mounted hand pump. When off the wheels it will sit down on 4 adjustable 2.5" dia. leveling pads. This should be a fun project and a good learning experience. To make it even more of a challenge I will be making my own hydraulic cylinders and hand pump. Though I haven’t finished up the base’s CAD drawings I have started milling out the hand pump.
The pump body starts out as a 3.5 x 3.5 x1 inch block of CR steel. Been very interesting drilling deep passage holes. Had one #24 drill that was about 3” deep. The chuck loosened up part way through and the bit got stuck. Vise grips to the rescue –no harm done. Then, trying to drill the ½” hole 2.5” deep for the pump piston cavity I broke off the a ¼” pilot hole bit down 1.75” . Had to use an end mill to cut the drill out then over cut the hole for a brass sleeve, better that way anyhow. So far all the drilling has been by CNC. Problem is you get no feel like a drill press.
