Hello lihaijiang
It is set aside because I don't have time to work on the machine. I'm a comercial pilot in Brazil, and have only 8 days off for month. In my vacation I will work on it, meanwhile I'm studying about it and figuring out how to install it in my machine.
regards
Raphael
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Sorry folks for not providing any updates over Christmas - this is mainly because there's been hardly any progress on my machine.
I had to shift it out of the way over Christmas and a load of my alu honeycomb also got damaged
I've pretty much decided to get it working soon as it is with the laos controller board but without any further mods, and then in a couple of months build a new cutter scavenging some parts from this one (tube, mirrors, lens, bits I've added and maybe steppers and power supply).
I'm going to do a writeup on everything I've done/planned to do and what I think worked/didn't work and I'll post a link on here once I've done that.
It's been interesting and I've learnt a lot but I think I have now realised the inevitable- it's never going to be as good as I'd like it in its current form.
Rob (Mowcius)
Oh and on I still haven't received a correct replacement laser lens from the ebay seller... yet.
Hi Raphael,Hello Tweakie,
I didn't understand weel your sketch-up. Just one doubt more; how do you get the 5volts from Z axis to fire laser? Do I have to use a voltage regulator, or can I setup it on mach 3?
Thank you
Raphael
The TTL input comes from the Computer's LPT port as an output pin controlled by Mach3.
Tweakie.
CNC is only limited by our imagination.
Ohh my god Tweakie,
How could I never thought about it?! You are a genious!!
So, I can get the 5 volts directly from the LPT cable from computer, and don't need the TB6560 Z axis to control it (I thought I had to use the TB6560 card Z axis to deliver 5 volts to the laser power source)
My God, this is true; the computer deliver 5 volts to the board control, I get this 5 volts direct from the LPT port and conect to the spindle relay (just to have a safe machine operation) and than to the laser TTL.
Thank you very much for the tip!
Have a nice 2012
Raphael
Raphael
The output from the Computer LPT port is TTL logic (it may be 0 - 5 volts or it may be 0 - 3 volts depending on the age of your computer). If you run through your spindle relay, that will introduce unwanted delay and cause you problems (like 'dots' at the start and end of lines). The first two TTL in my circuit are there to provide the necessary buffering to give safe machine operation.
Hope this helps.
Tweakie.
If anybody's interested, I've done some further modifications to my laser (Full Spectrum 40w Hobby Gen.4). I posted a YouTube video showing some details of it. Best part is I have optimized the X and Y axis, adding about 3/4" of cutting area to each.
[ame=http://www.youtube.com/watch?v=J1ZNBix7dZw]Full Spectrum Engineering 40w Hobby Laser Modifications - YouTube[/ame]
Hey, do you want to see more videos on the lase machines....
you can get it here...
NeedhamLaser's Channel - YouTube
Sample video of Rotary laser machine:-
needham-laser.com
Hi, thanks for your great post and all of the detail very useful for me and it helped me when I ordered my cheap chinese laser from Ebay. I know this post is a bit dated but the information is still very good. Can you or anyone reading this suggest any alternatives for the exhaust fan or describe what you have done (if anything) to improve the exhaust fan? The 40 watt laser I have comes with the usual suction fan, but I find when cutting acrylic the fumes are excessive and I would really like to minimize them for health/safety reasons.
Thanks!
Many have added additional blowers etc. to resolve this issue (there are some related threads here OPLaser support forum ? View topic - Upgraded my laser exhaust).
In my workshop I have an overhead, ducted, extraction system which is pretty efficient and quiet but it was expensive to install.
Tweakie.
Thanks for the link and tip on overhead exhaust you have given me a few more options I hadn't considered I am going to test out an inline extraction "booster" fan on the existing hose and see if that works but if it doesn't one of the venting methods in your link looks perfect... and quiet, which is just what I need.
Thanks!
Good DIY work!
Great thread mowcius!
I just bought a Chinese SH350D Laser Cutter from eBay, going over it with a fine tooth comb and just about to attempt to clean and align the mirrors to make sure everything works as good as it should before I leave feedback. However I have to say, at this point I am very happy with it. I like the idea of the Alloy honeycomb, and LED lighting as it's a simple modification and within my capability. Did you get the LED's from eBay?
@Mowicus: Thanks for the great posts. I know its been a loooong time. Hows your machine performing and whats in the news for you?
@WolverineX: I too just bought a 40W China laser. I have not even tested it and its slowly in pieces as Im going down the same/similar path as Mowicus.
-Sam
