586,052 active members*
4,217 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Questions on the PM20 G0704 PM25
    Oct 2005
    225
    I just received a PM20 with the long table and the front plate is marked 750 watts for the motor power but I doubt it is really that strong. I was asjusting the rpm pot on the control board and was wondering what the max RPM should be. I have it set at 3500 RPM right now but it will go much higher. I think I seen upwards of 5000 RPM when I first turned it but backed it back down until I found out more about the maximum. I do not think the small plastic gear can handle to many RPM. Has anyone else raised the RPM and where did you stop?
    Tommy
    That's high compared to what other pm machines have maxed at, 3300 being the peak
    rpm reached by cranking the pot.
    Do you have a handheld tach to verify it?
    I wouldn't subject those gears to more than 3500 for any length of time.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2005
    225
    The handheld tach is reading within 1-2 rpm's of the machine's tach. I even thought the machine tach was wrong. I was worried that the gears would not hold up very long so I kept it at 3500 RPM. The plastic gear is the one I am really worried about. As soon as I get the lathe I ordered I am going to start modifying the spindle and get rid of the gears and hopefully put some better bearings in the spindle.
    Thanks Hoss for the heads up. I think the spindle will go close to 6000RPM the way it is. When I ordered the machine it was tagged as a PM20 but came with the big table and also the larger spindle motor but the motor does not have any markings or a tag on it.
  1. Replies: 5
    Last Post: 10-11-2011, 04:24 PM
  2. Ready to order: G0704 or PM25
    By slinger in forum Benchtop Machines
    Last Post: 05-16-2011, 08:10 PM
  3. G0704 BF20 Beltdrive questions
    By fragger6662000 in forum Benchtop Machines
    Last Post: 12-16-2010, 09:43 AM
  4. g0704 - first mill - questions ....
    By dsdmax in forum Benchtop Machines
    Last Post: 03-28-2010, 09:32 PM
