587,035 active members*
2,966 visitors online*
    Oct 2011
    SERVO LAG EXCESS Y AXIS (Y axis won't home)
    Dear All,
    As I wrote in a precedent post I bought a Mazak VQC20/50 controlled by a Mazatrol CAM M-2
    My problem:
    When I try to home Y, after moving Y+ by impulse, I finish with a message:
    "2 ECART TROP IMPORTANT AXE Y" wich can be translate by "2 SERVO LAG EXCESS Y AXIS"
    Does anyone have an idea?
    Mr Mazak told me that it can be a servo problem and I need a mitsubishi tech but I spend two much money in this tool...
    I hope there is a solution because I saw this machine working.
    Oct 2011
    With Eliseo's help (he send me the complete CAM M2 operator manual),
    I find the english message equivalent to french "ecart trop important axe Y"
    The english error is "SERVO LAG EXCESS Y AXIS"
    Thank you
    Some time ago, I had the same problem.
    Finally I had to replace Z axis encoder and clean position switches.
    Oct 2011
    Thanks again Eliseo,
    I'll first try to find the Y axis position switchs, I don't know where are they but I'll investigate this evening.
    Oct 2011
    Thanks... I've found I think the most stupid problem.
    After understanding how the "home" process works. I disassemble the Y axis protectors and inspect the screws, the servo, the belt... I move Y axis in direction of the proximity sensor and saw a big screw blocking the travelling!!!!
    The carrier forgot to remove it!
    Without this screw the Y axis can go near the proximity sensor and now...
  1. Z axis home problem
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-08-2021, 02:47 PM
  2. Z-axis home
    By gracemach in forum Fadal
    Last Post: 05-02-2011, 10:48 PM
  3. Z Axis can't find home
    By Doubleddaved in forum Haas Lathes
    Last Post: 11-22-2010, 08:18 PM
  4. A axis wont home why??
    By JohnCo in forum Mach Mill
    Last Post: 11-04-2009, 08:52 AM
  5. How do you home an A axis?
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 09-23-2009, 01:22 AM
