586,121 active members*
3,432 visitors online*
Page 16 of 17 614151617
Results 301 to 320 of 337
  1. #301
    Dec 2004
    1316
    Thanks.
    They did come out quite well. I may have to make an A frame and another storefront sign.
    Jason
  2. #302
    Nov 2007
    483
    Question. Obviously you have the skills to, but why haven't you upgraded your JGRO to a supported rail build? Even JGRO upgraded his not long after completing this build.
  3. #303
    Apr 2013
    Daddy's Hands in solid surface.
  4. #304
    Dec 2004
    1316
    I am in the process upgrading. The frame is basically completed so in a few months I should be up and running.
    Today I am lining up the 5 start lead screws to mount with the 2 bolt flange bearings.
    Jason
  5. #305
    Dec 2004
    1316
    Attachment 185310
    Sign size: each side is 24 inches x 13 inches
    This sign has aluminum plate screwed to the back for support. Each piece is about 15 inches long by 2 inches wide.
    This sign spends the entire day in the sun, so without support it will bend.
    Jason
  6. #306
    Feb 2013
    195
    T nuts and bolts
    what size "t" nuts did you use and also the bolts? and did you drill the holes with the cnc or drill?
    thanks
  7. #307
    Dec 2004
    1316
    Marti, are you referring to a particular post in the thread?
  8. #308
    Feb 2013
    195
    Quote Originally Posted by Jason Marsha View Post
    I saw the pic of your spoil board that had the T nuts and was wondering what size you used and the size of the bolts. And I was wondering how you did the holes and when you replace the board, will you remove the bolts and reuse them? So far I think this would be the best option for me. BTW, really nice signs you've made.
    thanks
  9. #309
    Dec 2004
    1316
    I have not used the T nuts in a long time as they are covered. The size was the 1/4" - 20 bolt size. You can use the cnc to drill the holes which will make it easy for future replacements.
    Jason
  10. #310
    Feb 2013
    195
    Jason
    thanks. If you're not using the t-nuts, what are you using to hold down your work piece? I thought about trying to use a t-slot bit to cut the board, but me and the router don't get along too well I guess one reason is, I've never seen anybody first hand try to route trim on a router table.
  11. #311
    Dec 2004
    1316
    I either clamp the material on the perimeter or I stick it down with carpet tape.
    You can build a T slot table using only a table saw. Cut strips lets say 2 inches wide for the bottom and cut strips 2 2/4 inches wide for the top. Center the 2 3/4" strips on top of the 2" strips securing with screws then repeat the process leaving enough space between the upper strips for the bolt shaft to slide through.
    Jason
  12. #312
    Dec 2004
    1316
    Just finished cutting an 8 foot sign on the JGRO. Will peel the masking later and finish sand.
    Jason
  13. #313
    Feb 2013
    195
    Jason
    thanks. I had initially thought about doing that, but wasn't sure if it would give enough support. But that was before I decided to use the 2x4 braces and was just going to rely upon a flat top to make it rigid. And I do love 'jigs' - a girl's best friend, so I think that's what I'll do and it'll be cheaper too. How does the carpet tape work and how is it different than double-sided tape?
    I'm trying to figure out how to make my CNC do everything! ... cut wood, cut upholstery fabric and foam, and cut glass. For cutting fabric or glass I could just use a board underneath, so that wouldn't be a problem. Now if I can just find the wheel.
  14. #314
    Dec 2004
    1316
    Carpet tape is flat double sided tape. Its cheaper (at least where I live) and you can get sizes that are quite wide maybe 2 inches.
    Jason
  15. #315
    Feb 2013
    195
    Jason
    THANKS ... cheaper is always better
  16. #316
    Apr 2003
    550
    Do you have any pictures of your machine and/or work. It sounds interesting..
  17. #317
    Dec 2004
    1316
    Quote Originally Posted by gmfoster View Post
    Most of the work I am allowed to show is in this thread. The machine is the standard JGRO and pics are early in the thread.
    I should be posting some other work soon as I have decent sized pieces of solid surface.
    Jason
  18. #318
    Dec 2004
    1316
    Attachment 185724 Click image for larger version.
    The 8 foot sign all cleaned up.
    Delivering the sign today will take pics after owner installs.
    Jason
  19. #319
    Apr 2003
    550
    Jason
    Jason
    I have followed your thread since the beginning sorry I was to vague. I was referring to Marti that even cuts glass with her machine...
    Yes Jason you have produced more on your JGRO than many have with multi thousand dollar machines.
    Garry
  20. #320
    Nov 2007
    483
    It has been a very impressive run.
