Originally Posted by
SRT Mike
Finally, given that a servo has a geartrain which adds a lot of drag, it lets the motor hold position easily... but the steppers I have bought previously usually have quite a bit of resistance to turning when off. You can feel each click as you turn the shaft, even when powered off. Is there a name for this trait and is it measurable or disclosed on datasheets?
The term is detent torque.
What makes you think you need a gearbox with a servo? especially at that rpm.
Servo's are quite capable of very low rpm, the torque is fairly flat over the rpm range, it is just that steppers generally have a higher torque for a given Nema size.
You would not even hear a DC servo at the rpm. Agreed the feedback puts the price up a bit, but you have positioning down to the resolution of the encoder, and x4 that for systems that detect the quadrature pulse edges.
Al.
Al.
Albert E.
