Hello, I am a rocketry enthusiast and a friend of mine found out that I have access to both a CNC router table and a CNC 4D.
I need to cut a piece of 0.04" carbon fiber laminated in west systems 105/207 (regular laminating resin) into hopefully 6 fins. The piece is about 6"x6" but he only wants 5.5"x5.5" to be milled for use since the edges lose thickness and strength.
The way i currently have it set up, the blank will have about 1/8" or 3/16" between.
I'm unsure on how best to go about cutting this. It's too small to use a regular saw, and I do not have access to extremely strong thin cutting tools, so I thought that the CNC router table would be the best option. The cutter can spin at upto ~21k RPM (i think), and I have a lot of cutting bits to choose from. I need the cutting bit to be no more than 1/8" to make sure that no fin loses material due to an overly large bit.
Is what i hope to do possible or should i attempt it with a different tool/machine?
