586,512 active members*
3,300 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > C series drive current problem, need help
    Hi!
    I have problem in my C series drive.
    The drive is A06B-6066-H008. After the one hour work it stops and message
    "SV003 Y abnormal current is servo" appears.
    The LED indicate "8" in the drive.
    I dismounted drive and found the board A20B-1005-0210/02A.
    4 magnetic contactors build in this board. This contactors are very hot!
    Is it normal or it is problem in contactors?
    JBT transistor's radiators not so hot as connectors
    This are photo of servodrive parts:
    Attached Thumbnails Attached Thumbnails Главная плата п&#1.jpg   Магнитные пуск&#10.jpg   Привод Y.jpg
  1. Current draw of 2 PNP sensors in series
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-08-2011, 07:15 PM
  2. R2E3 Series I, Current or Voltage Loop Controls
    By krz2_2000 in forum Bridgeport / Hardinge Mills
    Last Post: 08-02-2007, 04:02 PM
  3. Main current for a drive? (BRU-200)
    By toninlg in forum Servo Motors / Drives
    Last Post: 06-02-2007, 07:27 PM
  4. Current resistors series or parallel?
    By JW Peters in forum Stepper Motors / Drives
    Last Post: 04-11-2006, 05:33 AM
  5. Drive current to low?
    By CRFultz in forum Gecko Drives
    Last Post: 04-30-2005, 04:33 AM
