586,033 active members*
3,495 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Belt question for Partner 4
    Sep 2010
    529
    My 1992 Partner 4 has some headstock noise after sitting unused for three years. I had the spindle running for an hour or so yesterday and it's sounding better, leading me to believe it could be belt related instead of bearings in the quill/spindle.
    My machine uses a VFD and has no variable speed reeves pulley system, according to the build sheet I need a BX-35 V belt for the motor to spindle.... but it appears from my parts list that I could have another belt to drive the back gear, it shows a part number of 230H, but it doesn't state what height, seems they come in 75 (3/4"), 100 (1") and so on up to several inches wide.
    Does anybody have a clue what size is in there.... or if that belt every needs changing? Figured I would order in spares to have here when I tear into it....
    Jul 2010
    548
    back gear belt
    the back gear belt is located under the "bowl gear" you would need to disassemble the upper head to get to it. These belts do not normally get alot of ware. My educated guess is the 1" width. H230100.
    Sportybob
    Sep 2010
    529
    I did replace the BX-35 belt (with the help of a friend) and we found that the drive pulley on the motor was hanging about a 1/4" low. Loosened the pulley, slid it up to the shoulder on the motor shaft, tightened and installed the new belt and things are much quieter.
    I still have some noise, doesn't honestly sound like belts though, suspect a bearing or two in the drivetrain somewhere is rattling just a bit... good news is the actual spindle bearings sound/seem ok though.
  1. Another belt question
    By fatboy55 in forum Charter Oak Automation Support Forum
    Last Post: 06-26-2011, 02:19 AM
  2. Timing Belt Question
    By jimbar99 in forum Linear and Rotary Motion
    Last Post: 03-14-2011, 11:58 PM
  3. Partner knee mill question
    By borne2fly in forum Milltronics
    Last Post: 10-07-2010, 05:13 AM
  4. Another belt drive question
    By AGA-man in forum Benchtop Machines
    Last Post: 11-14-2007, 10:41 PM
  5. Question about belt reductions
    By millman52 in forum Waterjet General Topics
    Last Post: 01-29-2007, 01:16 AM
