586,082 active members*
3,629 visitors online*
Thread: Extrude cut
Results 1 to 7 of 7
    Oct 2007
    34
    Extrude cut
    Hi Guys,
    I need your help on how to cut extrude 2 parallel slot. I'm still new on solidworks and doesn't have any formal training.
    I attached the file together for you guys to see.
    Thank you so much
    MrSammy
    Attached Files Attached Files
    Jan 2004
    3154
    Pick a surface or plane
    Draw the shape of the slots
    extrude cut them
    www.integratedmechanical.ca
    Nov 2011
    14
    Obviously you have made your Sketch 1 which is some sort of surface and now have Sketch 2 which should just be your slots? High light Sketch 2 in the manager on the left and then click Cut Extrude, the menu will come up and you can assign the depth.
    Oct 2007
    34
    Mr MatthewBasaraba,
    Thanks for your reply. Is that able to cut extrude to an angle, let say 47 degree? Because to my little knowledge, whenever i did cut extrude, it always goes straight (to any depth of course).
    By the way once again, million thanks to all of you.
    mrsammy
    Nov 2011
    14
    A little more information would help. If you making these slots into the main section then I would make the slot cut then apply a designated degree champher around the slot.
    If these features are external,rising above the part, you would need to determine the overall size minus the degree by the height and give it that OD then apply the degree of champher to apply the angle.
    I am still not a Solid Works pro but if I needed these features, that's how I would do it. Might be others that have different methods they can share. A section view of a print, if available, would greatly increase the ease and accuracy for people to share how to construct these features.
    Dec 2010
    1230
    if you are trying to get them to extrude at 47 from the surface you drew then on you get to learn new techniques
    try insert reference geometry, plane. create the plane above the surface where you want the top of the extruded part at your desired angle from the original surface. make view regular to the plane so your looking right at your old sketch. create new sketch on your new plane. click the old sketch. click convert entities to copy the old sketch to the new plane. now whatever you do will be at a 47 degree angle to the original surface. you can use planes for ANY type of angle or just about anything else.
    hope that helps, I'm not on a pc so I cant see your
    My solidworks instructor would change the name of the class to "Using planes and Solidworks too" if they would let him. reference geometry is VERY powerful and will frequently be the answer to the questions you don't even have yet.
    Oct 2007
    34
    PriddyShiddy
    Thanks a lot for the reply.
  1. Extrude a cut?
    By phil m in forum Rhino 3D
    Last Post: 12-23-2013, 11:25 AM
  2. Extrude or Revolve?
    By DCogswell in forum Solidworks
    Last Post: 06-07-2011, 11:08 PM
  3. Can't extrude.
    By 7yler in forum BobCad-Cam
    Last Post: 10-03-2010, 12:16 AM
  4. how to extrude
    By gits in forum Solidworks
    Last Post: 09-11-2010, 06:53 PM
  5. extrude slot at angle
    By PETE1968 in forum Autodesk
    Last Post: 04-11-2006, 02:01 AM
