Need Help - 104 y servo error too large. Just installed a replacement power supply from Haas and am receiving this error. 104 y servo error too large. This is on a Haas mini mill 2005
Thanks.
Thanks.
Maythem
Check if there is a red light on Y axis amplifier.
or you can disable Y axis to troubleshoot
Settin 7 to off > ENTER
lookfor
Prameter 15 >> scroll down with right arrow until DISABLED, change to 1(Press ESTOP)
Y axis will dissapear from screen and you should be able to power on with No alarms
if so, then suspect of amplifier
Good luck
Robby
Also check 12 VDC power applied to servo-amps
comes from LVPS (Yellow, WHite and Black wires)
Yellow +, White -, black common
Robby
There are many things that can cause a Y-axis servo error. Disabling the axis is a good start to pinpointing the issue. You could also call the Service department at Haas Automation for trouble shooting advice at 805-278-8500.
If this is something new after the power supply replacement, then double check all cables and make sure the low volt power supply cable to the y drive is plugged in and making good connection.
Back up and running. Y axis motor replaced, Y axis driver replaced and replaced power supply. $3500.00 in parts. Thanks for all the help. This is the first major problems I have had with this machine. Bought new in 04 Haas mini mill
