I have a bunch of small parts (.625x2.75x.063" thick) that have holes in them and I need to hold them down. There is only about 1/16 of area that I can use for vacuum on each side of the holes. So o-ring or other type of channel gasketing is out of the question. So I need some way that I can vacuum hold these down to a fixture plate (Dedicated fixture) and am lost for ideas. Both cuts (the circles and the profile of the part) are cut on the outside of the shape. In other words there's a 1/16" tool path around each 0.195"d circle and there isn't much left to gasket.
I tried placing the part right on the chambered PVC dedicated fixture board (no gasket) and it won't even think about holding down (leaks right past the workpiece). So I need some sort of gasket sheet maybe or some other form of seal I can use.
Any help would be appreciated!
I have a 1HP vac pump that works good for dedicated part holding in the larger parts I've cut so far. This one has me baffled.
