586,119 active members*
3,652 visitors online*
Results 1 to 6 of 6
    Mar 2004
    1543
    Galil reverse axis direction
    Is there a way to reverse the axis direction using native Galil commands?
    My reason is for homing. The CN command determines homing direction. I'd like to home all the axis simultaneously. Two axis need CN,-1 and two axis need CN,1. If I could temporarily flip the direction, all axis could home at once. Then change the direction back.
    Karl
    24221
    It is done using the CE and MT commands.
    One reverses the encoder, the other the motor command.
    But still not clear why you would want or have to do that?
    Al.
    Albert E.
    Mar 2004
    1543
    Thanks Al,
    Today two axis are homed
    CN ,1
    SP 5000,,5000
    HMXD
    BGXD 'home the X and W axis
    Then the other two
    CN ,-1
    SP ,5000,5000
    HMYZ
    BGYZ 'home Y and Z together
    If two axis were flipped, you can home everything at once
    CN ,1
    SP 5000,5000,5000,5000
    HMXYZD
    BGXYZD
    Karl
    24221
    Have you considered changing the state of the Home switch for the ones you want to reverse the home direction?
    Al.
    Albert E.
    Mar 2004
    1543
    Ya, I suppose that would work also. But I'm partial to NC switches. Any kind of failure results in an open. With NO, you can have a failure and not know it. Plus, I already wired it. Software is easier.
    Thanks for the help.
    Karl
    24221
    That is usually the case for O/T sw's, with home switches it usually does not matter as all that will happen is that it will try to home in the wrong direction and hit the opposite end O/T.?
    Al.
    Albert E.
  1. Reverse Direction
    By timerie in forum BobCad-Cam
    Last Post: 09-26-2011, 04:29 AM
  2. DC motor reverse direction
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 04-16-2010, 08:42 PM
  3. Reverse Motor Direction
    By electric2u in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2010, 06:46 AM
  4. Reverse direction?
    By HakBot in forum G-Code Programing
    Last Post: 11-19-2007, 11:30 PM
  5. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
