Hi, I'm a little new to all this, so if my terminology or placement is stupid, let me know.
I work on a Haas mini mill, using NX7.5 to make my code. all the parts i make are fairly irregular bodies, single part, double sided. One of the things i always need is a hole array in the part, usually offset from the edges by a bit, and so on. i've figured out how to set up the holes specifically in the part, and assign them to be cut, but currently, my machine only reads the first retract plane and ignores the rest, leading to it crashing. i've got a few solutions for this, none of which are particularly elegant. I'm wondering if there's a mill setting to recognize additional retract planes, or, alternately, if i need to rewrite my post.
Thanks in advance!
