I know its customary to tram the mill before milling. But with high cutting forces in all axis directions, and some loose parts of the machine, wouldnt you lose tram after a while, even during a run? So isnt tramming a little bit futile?
I havent done any 'precision' machining yet, so I just make sure my mill is relatively well trammed. But I've seen people tramming their mill by say tapping on the spindle or hammering some parts and then look back at their indicator to ensure 'perfect tram' to within the resolution of the indicator and go "wah la... perfecto!", is it a bit futile? I guess as long as the maching turns out to be within acceptable tolerances its the best you can do?
