I would like to get a PRS hollowbody style cutout done by someone here one the forum. I think that a bookmatched back that has been glued to the center block(to become sides) that is routed at the same time like the hollowbody II. The top is a seperate bookmatched and glued set. I would like to have the sides routed to accomidate two 1/4" jacks, and one hole for a 13pin midi. The same two position humbucker routes will be needed. The pickups will be active so there will be an additional 1/8" hole in the sides to accomidate power from the outside. The knob routed holes needed will be 2 for tone, one 3 way selector for the humb's, one coil tap, one more for volume(stacked pot for midi volume and master volume). I am planning on buying a prs 24 fret neck from ed roman guitars, so the standard prs neck joints would be needed. I will buy the wood, and glue the bookmatched sets and back to the center if glueing is needed before sending. Here are some pics of the body shaping that I am interested in.
