Well, we bought a brand new TM2. Finally getting around to powering it up. This machine is the first test bed for our facility to install a 400 watt laser in, since our other laser machines are soooo old. The entire spindle assembly has been removed, motor, unclamp cyl, spindle, cable track etc. I was able to get all the alarms bypassed through the control, except the spindle drive. The spindle drive is in the machine still, and has a green ready light. I would like to completely turn off the spindle axis, such as a A axis or whatever. The first guy I called at haas was pretty helpful, since i was able to bypass all the tool clamp/air etc alarms. Second guy not so much. He said to just hang the spindle encoder somewhere in the cabinet. Problem is, when our monkeys took the motor out, they pulled all the pins from the connector.
