586,102 active members*
2,485 visitors online*
IndustryArena Forum > CAM Software > Vectric > Two rail sweep for a walking stick in Aspire
    Sep 2005
    116
    I just completed two rail sweep for a walking stick. It starts as 0.8" round tapers 1.25" then to a hexagon back 1.25" round and then 0.8" again. I then V-carved the Serenity Prayer onto three of the flat sides (every other facet). I also V-carved text around the tapered round part. I started out with a 2"x2" (1.5"x1.5") I used a 0.25 end mill to cut it into a 1.25" dowel and then into the finished piece. I used a 45 degree V-bit to cut the text.
    Aspire's possibilities continue to amaze me!
    Attached Thumbnails Attached Thumbnails unrapped.jpg   wrapped.jpg   100_5768.jpg   100_5769.jpg
    Feb 2007
    532
    Wow... Very cool!
    For a 4th axis job like that was the work supported to cut it? I don't have a rotary axis but it seems like quite a thin work piece to me.
    Sep 2005
    116
    No supports. I just kept the cutting depth shallow (more passes). I used to have that problem with softwoods if I cut too aggressively. I found that by cutting less aggressively I had less sanding to do too...
  1. Questions on rail covers, dual servo hunting,and rail preload
    By Plugger in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2011, 05:00 AM
  2. Chip Sweep
    By timan in forum Haas Mills
    Last Post: 06-04-2007, 01:28 PM
  3. Sweep?
    By tt_raptor_90 in forum Solidworks
    Last Post: 06-05-2006, 12:27 PM
  4. Mastercam 2 Rail Sweep?
    By furry in forum Mastercam
    Last Post: 09-05-2005, 02:44 PM
  5. Sweep 1 rail problem
    By Splint in forum Rhino 3D
    Last Post: 06-20-2005, 06:15 AM
