586,103 active members*
3,514 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help on Fanuc 18m for Hardinge Conquest VMC 700
    Aug 2006
    Hello,
    I have been fighting with a problem for some time with a machine I bought a few months back. Our original problem was the Communications with the RS 232 port on the VMC. After re-searching and setting the proper parameters on the machine I could not get any posts to either "read" or "punch" from the machine. I called in our local CNC tech (ill leave out their name) and after 8 hours he could not get the com to work and after changing parameters for hours the machine will not read or write to a pcmi card in the back. I am consistantly getting an error to "turn off power" on the control now.
    Does anyone have a list of factory parameters for the control so I can manually reset them and start over? The only parameters changed are the ones for RS232 connection. Idealy I would like to check 0-300 (im not at the control) in the table to be sure everything is back in order.
    This has been frustrating to say the least. I called in a tech expecting to have this fixed. The result was a guy searching Google and randomly changing cable/ports/computers etc for hours. My computer even has com port conflicts now...though I can fix these.
    Any help would be greatly appreciated.
    I have found a great deal of knowledge just scrolling your site. Thanks to all for sharing.
    Chuck Blowers
    CJB Tooling
    Feb 2009
    6028
    Wow, sounds like you got hosed. That's why I always bring my laptop, and a known good cable. I can look up parameters on monday, but it's only a few for the rs 232. The card slot in the back on non i series controls only take SRAM cards, so a ata card wouldn't work. I don't know of any comm parameters that would make you switch off the control.
    Sep 2010
    1230
    Chuck,
    Unless there is a problem with your machine's control, communication via RS232 is quite straight forward with the Series 18 control, indeed all Fanuc controls.
    Regards,
    Bill
    Check that the following parameters are set as shown:
    Parameter
    #0000
    bit 0 = 0
    bit 1 = 1
    #0020 = 0
    #0100
    bit 2 = 0
    bit 3 = 1
    bit 5 = 1
    #0101
    bit 0 = 1
    bit 3 = 0
    bit 7 = 1
    #0102 = 0
    #0103 = 11 (9600 Baud rate)
    The Setting Page parameters have been set above, but check that they are correctly set on that page as follows
    TV CHECK 0 0: Off; 1: On
    Punch code 0 0:ISO; 1:EIA
    Input device 0 RS232
    The above setting of parameter #102 selects Xon Xoff (Software Handshaking) at the control. The cable pin out for Xon Xoff handshaking is as follows:
    Machine Side -------------------------------------- PC Side
    DB25 Male Connector --------------- DB25 Female ------------DB9 Female
    1----Cable Shield --------------------Not Connected ----------Not Connected
    2 ------------------------------------------ 3 -------------------------- 2
    3 ------------------------------------------ 2 -------------------------- 3
    4
    | bridged
    5
    6
    8 all bridged
    20
    7 ------------------------------------------ 7 -------------------------- 5
    PC Software Setting
    Handshake Method = Xon Xoff
    Baud Rate = 9600 (Same as Control Setting)
    Data Bits = 7
    Stop Bits = 2
    Parity Bit = Even
    Aug 2011
    Does anyone have a list of factory parameters for the control Fanuc 18m for Hardinge Conquest VMC 700.
    Any help by mailing would be greatly appreciated
    U Periasamy
    [email protected]
  1. hardinge conquest 51
    By mikemck in forum Hardinge Lathes
    Last Post: 11-16-2015, 02:33 PM
  2. Hardinge Conquest T 42 FANUC 0T optional parameters
    By bobancurug in forum Hardinge Lathes
    Last Post: 09-20-2015, 04:17 AM
  3. Replies: 1
    Last Post: 02-04-2013, 12:59 PM
  4. Replies: 0
    Last Post: 12-22-2010, 11:17 PM
  5. Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 01:10 PM
