586,052 active members*
4,217 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 cutting size wrong
    Feb 2006
    174
    I am having a problem. I have gecko servos on the rest of my mills so I thought I would try a stepper. On a unit that has the same ball screws that are on my other units. I am using the same code as on the others. I have my steps set to 10160 and the unit will move 49 inches. In mach it says 49 inches. But when I mill a piece it is always .015 smaller. It makes no difference if the piece is 1 inch or 5 inches it is .015 smaller. I have changed the spindle and collect still .015 smaller. Any idea.
    Thanks Ed
    May 2010
    313
    Quote Originally Posted by Ed Williams View Post
    Thanks Ed
    repeatable backlash?
  1. My parts are coming out the wrong size!
    By bremerr in forum DIY CNC Router Table Machines
    Last Post: 12-18-2015, 04:43 PM
  2. G540 doesn´t work. What may be wrong?
    By jaru-eri in forum Gecko Drives
    Last Post: 10-07-2011, 10:14 PM
  3. EMC2 and G540 help needed. Wrong way Homie.
    By pencilneck in forum DIY CNC Router Table Machines
    Last Post: 05-12-2011, 12:40 PM
  4. Wrong Ballscrew Size?
    By ozzie34231 in forum Linear and Rotary Motion
    Last Post: 01-04-2008, 06:23 PM
