So first it started with my inital design, which had some serious flaws....So here is the current design, although the gantry is currently a work in progress.
The goal of the machine was to design a CNC that met the following criteria:
Machine Size: 20"x20"x19.5"
Travel Distance: Goal was 14.5 x 16.5 x 7.75, but that's a work in progress.
Materials: Aluminum and Steel
Precision Goal: .001"
Budget: $800 (lol)
Its purpose, aside from cutting things, is to allow me to create small aluminum prototypes for other projects - It'll also be doing PCB's and other wood / polymer jobs. It was designed to be a small "desktop" unit but I'm starting to doubt its 100+ lb foot print will sit well on my glass top desk.
I apologize for the ****ty phone pictures, I sold my DSLR to fund this project haha
It was designed bottom-up (dumb modeling) in Solidworks 2011. But I'm now considering re modeling it in Catia V5 using relational (top-down) methods.
The first thing I tactled was the base, it's made of "8020 T-Slotted" extrusions. Which are 6061-T6 Aluminum. I took this inspiration from a lot of other DIYers on CNCzone and internet in general - and it was a good decision. Very cool stuff.
The vertical supports (I call them uprights) are made from 5/8" hot rolled steel plate and were a HUGE pain in the rear to cut and shape.
Because of there thickness, holes 1/8" away from the actual surface were cut at directional changes in the design (aswell as interior cut out). Then outlined using a high precision process involving a straight edge and a sharpie .
Then, the dots were connected using a band saw. About 4 hours later this essentially left me with a rough outline of the shape with 1/8" of extra material. Then these pieces were placed in the CNC and the edges were rounded off and other details added.
Roughly 9 hours after the CNC's had their way with them. They were done!
So now the entire base structure is completed.
The linear rails seen in the picture were purchased as 1 long continuous 7' length, so they were cut down to size using a grinder... But unfortunately now the hole patterns are completely inconsistent and a way needed to attach these to the 8020 base structure.
So using a C02 laser at the university, 3/8 acrylic plates was cut and will be used as "adapter" plates to attach the linear rails in the X and Y axis.
So here is where i currently am in the project....Its now time to begin purchasing aluminum plate to create the gantry and Z axis systems.
But first i'll need to make some changes to my design. Just a warning, this is going to be a LONG project as I'm currently a senior mechanical engineering student at UCSD and i'm pretty busy with school and work.
But feel free to leave comments and advice
