586,076 active members*
3,893 visitors online*
    Jun 2008
    5
    Parts conveyor time
    Hello everybody,
    Does anybody know, how can I extend a time of Parts conveyor moving? I found something in a operation manual like Keep relay K8.5 - TM45 - "Set the operation time of parts conveyor after commanding M11 (setting unit:msec)", but I don´t know where can I find it in a machine setting.
    Thank you in advance for reply
    Miroslav Uherec,
    Machine - Doosan Puma TT1800SY, Fanuc 16i TB,
    2932
    First of all, BE CAREFUL when changing parameters.
    You'll have to enable Parameter Write (see attached .jpg). You will get an alarm 100... ignore it.
    Then press:
    SYSTEM
    [ PMC ]
    [PMCPRM]
    [TIMER]
    cursor to the one you want to change, key in the time in milliseconds, then press INPUT.
    Go back to SETING and set Parameter Write = 0.
    Press RESET to clear the alarm.
    Jun 2008
    5
    Hello,
    First, many thanks for quick reply!
    Because it is not very clear, I attached saved timer screen from machine and scanned list from operation manual, if that TM45 is really that one. But that is little bit confusing, the time is set to "0"?
    Miroslav Uherec,
    Attached Thumbnails Attached Thumbnails operation manual.jpg   timer screen.jpg
    2932
    Quote Originally Posted by mira.uherec View Post
    Hello,
    Miroslav Uherec,
    I believe you are looking at the information when the machine is equipped with Parts Catcher A. If your machine is equipped with Parts Catcher B (Option) then TM45 is not used. See attached .jpgs.
    Attached Thumbnails Attached Thumbnails Daewoo TT1800 Parts Conveyor (B option).jpg   Daewoo TT1800 Parts Conveyor Timer (B Option).jpg
    Jun 2008
    5
    Solved
    Hello dcoupar,
    I was really looking on the wrong command. M311 was that one I should been looking to, so many thanks for your quick help!
    Mira
  1. Chip conveyor on 6030
    By 5th-axis in forum Fadal
    Last Post: 12-06-2010, 02:51 PM
  2. 1 Time run cnc lathe parts
    By 69owb in forum Employment Opportunity
    Last Post: 07-28-2010, 09:07 PM
  3. Replies: 5
    Last Post: 05-29-2005, 03:17 AM
