586,076 active members*
3,874 visitors online*
    Sep 2011
    29
    CNC 6040 home switches
    G'day,
    Disclaimer: I am completely new to CAM and CNC, I have no real electronics knowledge, I have got most of my info from this awesome forum.
    Looking for some advice here or even a design or even for some lovely person on here to build me what I need (for a fee of course).
    I have the Chinese CNC 6040 with a GeckoDrive G540 with a BOB and I want to have homing capability. The PC is running EMC2.
    A 5m serial cable will be attached to the BOB in the G540 enclosure and I think the other end of the cable will go to a homing PCB.
    I mean I know I need 3 environmentally sealed switches and maybe some other electronics (DB9 connector).
    The list of stuff I don't know is alarming me!
    The type of switches to use
    Wiring the switches up
    Placement of the switches
    Any extra sticky out bits I need to help trip the switches
    If only there was a kit for the 6040!
    Thanks for looking and I hope somebody can help.
    On the off chance someone is local, I am based in Sydney.
    Cheers
    Richard
    Oct 2008
    406
    Have you checked out the thread on Hall-effect switches http://www.cnczone.com/forums/open_s...made_easy.html
    They're a magnetically operated IC, totally sealed and easy to mount and wire.
    Bob
    "Bad decisions make good stories."
    Sep 2011
    29
    Thanks bobsch, thats a great thread.
    But, the G540 is an issue with the hall-effect switches:
    The G540 inputs are internally pulled up to 12V inside the unit, the switch closes, it needs to connect the input to 0V.
    The G540 has a GC-04 breakout board in it.
    http://www.homanndesigns.com/pdfs/GC-04R1.pdf
    The 4 inputs of the G540 are connected to the top DB-9 connector on pins 1,2,3,4 respectively. Pins 6,7,8 on the same connector have 0V on them
    So basically I need mechanical switches (or a separate PSU but I don't like the idea of another PSU).
    Richard
  1. Home switches and Limit Switches
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 03-12-2011, 12:08 PM
  2. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  3. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  4. home switches?
    By ljoe1969 in forum Xylotex
    Last Post: 06-05-2004, 07:57 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
