586,077 active members*
3,767 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Is this a ground or rolled ball screw
    Jan 2007
    17
    How do I tell if this is a ground or rolled ball screw, My first thought was it is a ground ball screw but then I noticed the groove on the land which I have seen on a lot of rolled ball screws.
    All I know for sure about the ball screw is it is at least 12 yrs old.
    If it is a rolled ball screw is it worth sending out to be ground, if that is even possible with a rolled screw.
    Mar 2006
    2712
    Appears to be a rolled ball screw. I would ASSume a rolled ball screw could be rolled over-size then ground to final dimensions later.
    I do not know if a rolled to final dimension ball screw can be ground as a substitute for an original equipment ground ball screw.
    Maybe mikeKilroy knows.
    Dick Z
    DZASTR
    Sep 2010
    717
    It's rolled. The extra groove comes from the rolling process. (I don't know why exactly).
    The ground screws I have do not have the extra groove.
    Hub
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Oct 2005
    2392
    Quote Originally Posted by hub View Post
    Yep. The "extra groove" you described is the space between the displaced material, displaced from the middle of the grooves to the outer edge during rolling.
    Sep 2010
    1765
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    ha!just cuz we r thomson screw distributor? i can say i never heard of someone grinding a rolled screw... why do it? for more accuracy I assume? but i think the .003" typical (OTOMH) per foot accuracy of a rolled screw is due to the rolling process: it goes thru a threader and so it comes out other side stretched and schrunk up some; ground screw has .0003" (IIRC) per foot typiucal becasue it is ground to exact dimensions, not forced/oozed thru a threading head. so seems to me like grinding rolled screw cannot help accuracy cuz the threads are in the wrong place.
    but maybe some of the screw rebuilders in MI CAN do this? they take worn out screws and weld in new material, then come back and machine it down again....
  1. Ground ball screw source?
    By jhncaj in forum Linear and Rotary Motion
    Last Post: 08-12-2010, 10:57 PM
  2. rolled 5/8 ball screw.200 pl
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-02-2008, 03:09 AM
  3. Replies: 10
    Last Post: 01-16-2007, 06:27 PM
  4. Anyone looking for a Precision ground ball screw...
    By Dave's_Not_Here in forum Linear and Rotary Motion
    Last Post: 06-23-2005, 03:33 PM
  5. Rolled or Ground ball screws
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 12-22-2004, 04:11 AM
