Jgro Router Pipe Support.
I am very close to finisishing a Jgro Router. It may cut or engrave something to-night.
I have thought a lot about Pipe support especially on the long Axis. I think I have solution which I will implement. This solution is, extend the bottom torsion box top skin out to level with the end supports in 3/4" MDF, (There is just enough clearance with the bottom of the gantry you may want to provide a little more), then put some sides on that are bolted into the edge of the skin, what's a few more edge tapped MDF threads.
This assembly should be rigid enough to use to support the pipes with packing and shims or adjustable bolts and locknuts. The support may only be needed in one or two places.
Just my 2 cents worth before you start.
Brian
The Sawdust Creator
