I am new to cnc but have been a bench jeweler making hand made wax models since 1989 .
[That should be a big help; some people with no understanding of what good jewelry models entail design things in CAD that don't really work in the real world.]
I bought the Roland jwx 30 because it was touted as easy and made for the jeweler as opposed to a machine you needed to adapt.My problem is this,I cannot find clear information ,if it exists,in creating jewelry and small scale sculpture on this or any other small machine.I would love to find some definitive information on feed rates,cutting depths for different bits and why without wasting any more time or wax and not damaging my machine.
[Fortunately wax is pretty cheap, at least in the sizes you're using, and you're unlikely to damage the machine (unless you get really frustrated). Wax cutting can be done at a fairly high rate of speed, but that goes down with the size of cutter you're using. The basic rule is that the tool has to remove enough material at each revolution to clear the path for its advance. So if your tool removes .003" of material per flute, and it has two flutes, then you can advance .006" per revolution. If your spindle is running at 10,000 RPM, that works out to 60 inches per minute. The rule of thumb for depth of cut is not to go deeper than half the diameter of the tool at a time.]
I also would love to know cutting strategies for undercut pieces or deep cut pieces where a bit might have trouble reaching,etc.
[Your machine can only cut the areas that it can reach with a tool. It's possible to design parts that it cannot completely cut, if they are unreachable. If those undercuts are important to your design, cut what you can on the machine, and go in afterwards and scoop out the undercuts by hand; it's still easier than carving the whole thing by hand. For deep areas, you can adopt the same strategy, or use a longer tool. Straight endmills tend to be very short in the small diameter sizes; to work around that, you might try a tapered tool, which is stronger since the smallest diameter is just at the end. Bits and Bits
Engraving Cutters | End Mills | Tools for Milling Wax is a source for these. Another company, Precisebits, offers "deep reach" carbide tools which you might find useful. There's also a more in-depth discussion of the feedrate issue on the Precisebits site:
Calibrating Feeds and Speeds with Carbide Microtools ]
Any materials,books,online classes that pertain to jewelry or problems dealing with intricate pieces.I will be in your debt and if youre in the area i would buy you a steak dinner with top shelf liquor LOL!Just saying i will be very relieved to find some info...thanks Rich Berman
