586,116 active members*
3,288 visitors online*
    Mar 2009
    924
    Oil in a T100M torch line help
    How do we clean or minimize the oil that has managed to get in the line of a Hypertherm air torch? I removed my oil filter thinking My compressor was not leaking any oil into the lines (needed to make some room), well not so. Finding small amounts of oil on the swirl ring now and it coincides with decreased nozzle life, down to 800 pierces from 1500 pierces on 3/16".
    Can we use alcohol or something equally as explosive to clean out the oil?
    WSS
    www.metaltechus.com
    Jan 2008
    2247
    I would suggest talking with Hypertherm tech service directly...I'm sure they have run into this issue before.
    Jim Colt Hypertherm
    Nov 2009
    Hi WSS,
    If your compressor not leak, do you find where the oil comes from?
    I think it is because you removed your oil filter.
    Use some dishwashing liquid to clean the line and mount the filter on.
    Then check it again.
    Not use alcohol or fuel to clean, it can damage to the line.
    John
  1. SDS/2 and Arianna for Ficep Drill/Torch Line
    By sippelsteelfab1 in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 04:41 PM
  2. T100M PIP switch
    By WSS in forum Hypertherm Plasma
    Last Post: 03-17-2011, 07:23 AM
  3. Hypertherm T100M Machine Torch Cable diameter
    By Zaher in forum Hypertherm Plasma
    Last Post: 01-24-2010, 10:53 AM
  4. Hypertherm T100M Machine Torch Cable diameter
    By Zaher in forum Waterjet General Topics
    Last Post: 01-18-2010, 02:29 PM
  5. Hypertherm 1250 with a T100M torch??? Short consumable life
    By Brink_ in forum Waterjet General Topics
    Last Post: 01-08-2009, 05:28 PM
