586,105 active members*
3,357 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Post Processor for Mach3 Lathe Question
Results 1 to 17 of 17
    Dec 2007
    468
    I'm getting some really weird movements when I try to run a part in my lathe. I just got the lathe made and this is the first time I'm using it under CNC control to make some parts.
    The basic problem is that the lathe is going everywhere but where it needs to go. I don't dare let this actually try to cut a part, because the bit would be buried somewhere into the stock.
    Here is what I have done so far:
    Used the T-Mach3Rcss.ppr and T-Mach3DcssT.ppr processors. (Both do the same thing. Mach3 has radius mode on the screen. I tried Mach3R first and when that didn't work, I tried the other one.)
    In Config - General Config, I tried both the INC and ABS selections under IJ Mode.
    I went through all the thread titles (17 pages worth) and read everything that even remotely looked like it might be related.
    In DolphinCAM the part is cutting perfectly. If I could get it to do the same thing on the lathe, I would be a very happy camper.
    Anything that I am missing?
    I attached my practice file that I'm using. I used the Mach3R for this one. Line 190 starts a huge circle into my part.
    Mike
    Attached Files Attached Files
    Dec 2007
    468
    I just tried one of the Mach3 wizards and the lathe worked perfectly. I'm suspecting my problems is DolphinCAM outputting the G-Code or the post processor I'm using.
    I also ran the G-Code through CamBam and it is showing the same wonky tool paths. The tool is doing lots and lots of circles.
    Does anyone have ANY ideas where to go with this? I was hoping to run some parts today.
    Mike
    Dec 2007
    496
    What post are you using?
    Dec 2007
    468
    Quote Originally Posted by harley4ever View Post
    Tried both of these:
    T-Mach3Rcss.ppr
    T-Mach3DcssT.ppr
    Mike
    Dec 2007
    496
    Perhaps that's the problem. I am pretty sure there is a new revision.
    Dec 2007
    468
    The ones on the DolphinCAD site are the same ones...well...the names are the same.
    Any idea what one I am looking for?
    Edit: I downloaded the ones from Dolphin...they evidently are the same ones...still don't work.
    Mike
    Feb 2007
    414
    Can you send the PartMaster .cnc file please.
    ATB
    Andre
    Dec 2007
    468
    Quote Originally Posted by andre-dolphin View Post
    ATB
    Andre
    Give this a try.
    Mike
    Feb 2007
    414
    Have a look at the attached PDF file - this contains the PartMaster image of your part and the Gcode image from MACH3, I used the T_Mach3Rcss.ppr post.
    In Mach3 I set the IJ mode to Abs. Looks OK to me.
    ATB
    Andre
    Feb 2007
    414
    oops
    Dec 2007
    468
    Thats interesting.
    Mine is OK in Dolphin, but as soon as I load the G-code into Mach3, I get all the funny circles.
    Would you have the whole g-code file? I'd like to compare it to what generates for me.
    I'll give this a try later again. In the middle of cutting up a tree that blew over.
    Mike
    Dec 2007
    468
    Still doing the same thing. I'm using the T_Mach3Rcss.ppr post and IJ is set in ABS mode.
    Here is the code that generates when I run the post process. Starting at line N140 I get a big circle and then every 50 after that (N190, N240...etc...).
    My version number is 10,0,10002 if that makes any difference.
    Thanks for the help. I really appreciate it.
    Mike
    N20 G20 G18 G64 G80 G90 M49 G40 G49
    ; TOOL definition
    N40 M09
    N50 G00 X0.0 Z0.0 M05
    N60 ( Turning tool )
    N70 M06 T1 G43 H1
    N80 M03 G94 F7.874
    N90 G97 S500
    N100 G40
    N110 G00 X0.2504 Z0.0 G94
    N120 G01 X0.2361 Z0.0
    N130 X0.2361 Z-0.1792
    N140 G02 X0.2504 Z-0.2304 I-0.0315 K-0.2815
    N150 G00 X0.3685 Z-0.1123
    N160 X0.3685 Z0.0
    N170 G01 X0.2218 Z0.0
    N180 X0.2218 Z-0.1477
    N190 G02 X0.2361 Z-0.1792 I-0.0315 K-0.2815
    N200 G00 X0.3542 Z-0.0611
    N210 X0.3542 Z0.0
    N220 G01 X0.2075 Z0.0
    N230 X0.2075 Z-0.1236
    N240 G02 X0.2218 Z-0.1477 I-0.0315 K-0.2815
    N250 G00 X0.3399 Z-0.0296
    N260 X0.3399 Z0.0
    N270 G01 X0.1933 Z0.0
    N280 X0.1933 Z-0.1038
    N290 G02 X0.2075 Z-0.1236 I-0.0315 K-0.2815
    N300 G00 X0.3256 Z-0.0055
    N310 X0.3256 Z0.0
    N320 G01 X0.179 Z0.0
    N330 X0.179 Z-0.0871
    N340 G02 X0.1933 Z-0.1038 I-0.0315 K-0.2815
    N350 G00 X0.3114 Z0.0143
    N360 X0.3114 Z0.0
    N370 G01 X0.1647 Z0.0
    N380 X0.1647 Z-0.0727
    N390 G02 X0.179 Z-0.0871 I-0.0315 K-0.2815
    N400 G00 X0.2971 Z0.031
    N410 X0.2971 Z0.0
    N420 G01 X0.1504 Z0.0
    N430 X0.1504 Z-0.0601
    N440 G02 X0.1647 Z-0.0727 I-0.0315 K-0.2815
    N450 G00 X0.2828 Z0.0454
    N460 X0.2828 Z0.0
    N470 G01 X0.1361 Z0.0
    N480 X0.1361 Z-0.0491
    N490 G02 X0.1504 Z-0.0601 I-0.0315 K-0.2815
    N500 G00 X0.2685 Z0.058
    N510 X0.2685 Z0.0
    N520 G01 X0.1218 Z0.0
    N530 X0.1218 Z-0.0395
    N540 G02 X0.1361 Z-0.0491 I-0.0315 K-0.2815
    N550 G00 X0.2542 Z0.069
    N560 X0.2542 Z0.0
    N570 G01 X0.1075 Z0.0
    N580 X0.1075 Z-0.031
    N590 G02 X0.1218 Z-0.0395 I-0.0315 K-0.2815
    N600 G00 X0.2399 Z0.0786
    N610 X0.2399 Z0.0
    N620 G01 X0.0932 Z0.0
    N630 X0.0932 Z-0.0236
    N640 G02 X0.1075 Z-0.031 I-0.0315 K-0.2815
    N650 G00 X0.2256 Z0.0871
    N660 X0.2256 Z0.0
    N670 G01 X0.0789 Z0.0
    N680 X0.0789 Z-0.0171
    N690 G02 X0.0932 Z-0.0236 I-0.0315 K-0.2815
    N700 G00 X0.2113 Z0.0945
    N710 X0.2113 Z0.0
    N720 G01 X0.0647 Z0.0
    N730 X0.0647 Z-0.0116
    N740 G02 X0.0789 Z-0.0171 I-0.0315 K-0.2815
    N750 G00 X0.197 Z0.101
    N760 X0.197 Z0.0
    N770 G01 X0.0504 Z0.0
    N780 X0.0504 Z-0.007
    N790 G02 X0.0647 Z-0.0116 I-0.0315 K-0.2815
    N800 G00 X0.1828 Z0.1065
    N810 X0.1828 Z0.0
    N820 G01 X0.0361 Z0.0
    N830 X0.0361 Z-0.0031
    N840 G02 X0.0504 Z-0.007 I-0.0315 K-0.2815
    N850 G00 X0.1685 Z0.1112
    N860 X0.1685 Z0.0
    N870 G01 X0.0218 Z0.0
    N880 G02 X0.0361 Z-0.0031 I-0.0315 K-0.2815
    N890 G00 X0.1542 Z0.115
    N900 X0.2504 Z0.115
    N910 X0.2504 Z0.0
    N920 X-0.0315 Z0.0
    N930 G41
    N940 G02 X0.25 Z-0.2815 I-0.0315 K-0.2815
    N950 G01 X0.25 Z-0.5315
    N960 M05 M30
    Dec 2007
    468
    Here is the screen that I see in Mach3.
    Mike
    Dec 2007
    468
    I tried reinstalling the program on a different computer. Same results. I still get the line starting at N140 with the circles.
    Anything else that I can try?
    Mike
    Dec 2007
    468
    Andre,
    Is the T_Mach3Rcss.ppr post that you are using the same one that is on the download page on the Dolphin site? Just curious if maybe I have a different version of the post.
    Mike
    Feb 2007
    414
    I have attached a zip file that contains the .cnc, .pun files and the post I have been using.
    See what results you get, if they differ I can only think that it's a setting in mach3 - I haven't setup mach to actually run a machine. I just use it to test gcodes.
    IJ mode in Config is set to Abs.
    ATB
    Andre
    Oct 2004
    832
    It will either be your IJ mode or that you need to select reversed arcs in front toolpost, you will find the latter in Config menu then Ports and Pins then Turn Options.
    Hood
  1. Post Processor Question- Mach3
    By bjorn toulouse in forum CamBam
    Last Post: 04-10-2011, 01:56 PM
  2. Mach3 Incremental IJ Post Processor
    By ftech in forum Dolphin CAD/CAM
    Last Post: 02-04-2011, 02:55 PM
  3. Which Post Processor for Mach3?
    By WarrenW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-23-2009, 10:16 AM
  4. Post Processor For Mach3
    By southernexplore in forum BobCad-Cam
    Last Post: 03-09-2006, 07:10 PM
