586,655 active members*
4,361 visitors online*
    Jul 2011
    86
    Upgraded to latest version, y axis strange behavior
    I upgraded to the latest version today and now my y axis is not running normal it kind of sputters and does not move at the normal speed. All settings are the same as the old version and X A Z axis are working normally.
    When it installed it did the parallel driver, could that cause this or do you think this is a driver board issue?
    I checked and the stepper is fine, the board is a TB6560.
    Any ideas how to un install the parallel driver that was included with the software?
    The old version of Mach does not communicate with the driver board anymore...
    Time for a G540? :violin:
    I believe the manual tells you how to uninstall the driver. Then just re-install the older version.
  1. Strange behavior with VFD
    By BanduraMaker in forum Gecko Drives
    Last Post: 11-15-2011, 03:00 PM
  2. NM-200 - strange behavior?
    By kvom in forum Novakon
    Last Post: 07-29-2011, 12:14 AM
  3. NM-200 - strange behavior?
    Last Post: 05-24-2011, 02:28 PM
  4. Strange Behavior.
    By riveracnc in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2008, 01:54 AM
  5. Milltronics strange behavior
    By KBHone in forum Milltronics
    Last Post: 12-10-2007, 12:00 AM
