586,540 active members*
2,878 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > mori sl2h yasnac lx2 how to enable error pulse page
    Oct 2006
    71
    Ive got an 85 mori sl2h with yasnac lx2 control. Im seeing that my arcs using g42/g41 are a little off. I dont see any measurable physical backlash in x or z. I think I need to adjust or at least check my following error on x and z to match (z to be double that of x). I think theres a way to set one of the parameters so that you can see an error pulse page in the position page on the control. That way I could adjust the gains on my servo(s) if theyre off. I dont remember what that parameter or its setting is. Anyone know that trick?
    2932
    Set the System No. switch on the tape reader to 4.
    Oct 2006
    71
    Yes, That was it, thanks a lot!!
  1. Mori Seiki CL-20A YASNAC
    By lalorockero in forum Mori Seiki lathes
    Last Post: 07-20-2013, 06:01 AM
  2. Pulse output on enable
    By kingofl337 in forum Mach Mill
    Last Post: 08-15-2011, 04:05 AM
  3. Mori sl2h OT in X in dry run
    By markp in forum Mori Seiki lathes
    Last Post: 06-13-2010, 09:29 PM
  4. looking to buy a Mori SL2H / need advice
    By teamjnz in forum Mori Seiki lathes
    Last Post: 05-01-2009, 04:31 AM
  5. Mori Jr with Yasnac MX2, a little help
    By dannystooblue in forum Mori Seiki Mills
    Last Post: 09-24-2008, 04:00 AM
