EMUFDD 4.0 - USB Floppy Disk Replacement / Hardware Emulator
* comes to you with all supported floppy interfaces within an unique firmware, jumper-free configurable
* loads data directly from USB-key standard DOS directories
* is the only emulator that loads/saves data also in ISO standard format, readable by every virtual floppy software and floppy low level editor
* can emulate system floppies, particular floppies that can't be simply copied but need a clone operation
* can emulate any non-standard floppy format (640Kb/800Kb/1.28Mb/...)
* EMUFDD + Virtual Floppy Drive (VFD) is a complete data exchange system, more than a plain floppy emulator
* is an original product, designed & assembled in Italy since 2009
EMUFDD lets:
* any computer and industrial machinery go on working, without hardware or software change
* people just switch off, replace the old drive and turn on: complete stand-alone hardware emulation
* people go on working, avoiding or deferring expensive machinery replacement
* load data into the internal memory & plug the USB-key off : no need to keep the USB-key always plugged in
* customers rely on a prompt and effective technical support - direct line with the designer
