586,075 active members*
3,714 visitors online*
Results 1 to 8 of 8
    Sep 2011
    40
    g53 in macro/script?
    Running a syil x4 with mach3
    I set up the auto tool function to work with a touch off plate. But I want the auto-tool button to send the tool up and then over to the plate location.
    It is located at -9.798,-.577, -7.502 in machine coordinates. I tired using g53 but got an error that machine coordinates are not allowed in the script. So now I have to remember to find the m6 call out each time and enter g53 x-9.798 y-.577 before the m6 line. It's not really a pain to do since we run short programs, I just don't want to ruin anything as I am not the only one who uses the machine.
    How can I go about doing this?
    You can use
    Code "G0 G53 X-9.798 Y-0.577 Z-7.502"
    in your script.
    Sep 2011
    40
    Wow, thanks.
    So I just needed g0 before the g53 command?
    Sep 2011
    40
    also, since I have your attention, what do I use to make mach3 wait before going to the next line? I want it to finish moving before displaying a msgbox advising to change tool now or that the job is finished.
    I don't know, as I've never seen the error you got, or what you were trying to do. But what I posted will do what you want.
    Jun 2007
    394
    Quote Originally Posted by travisn View Post
    A dwell could be used, G4PX where X = num of seconds
    Anytime you have movement occurring in a script, it should be followed by:
    While IsMoving
    Wend
    To make sure the move is completed before further code is run.
    If you want to pause, use:
    Sleep(1000)
    for 1 second. (# is milliseconds)
    It's good practice that anytime DRO's need to be updated, that a minimum of 1/10 second delay ( Sleep(100) )be used to allow the DRO's to update before moving on. Failure to do so may cause problems.
    Sep 2011
    40
    got it, thanks. I'll update my script tomorrow.
    next task is making a pnp....
  1. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  2. VB6,VB.net,VB script,What one???
    By hydrospin01 in forum Visual Basic
    Last Post: 05-25-2008, 02:09 AM
  3. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
  4. Lookahead Script
    By Rikard L in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-10-2007, 08:06 PM
  5. Macro/script-can this be done?
    By Splint in forum Rhino 3D
    Last Post: 02-13-2006, 04:50 AM
