586,115 active members*
3,496 visitors online*
Results 1 to 3 of 3
    Nov 2011
    X axis problem
    Firstly sorry if this is in the wrong section I'm a new member and only getting used to this forum? Admin feel free to move it to the correct place?
    My problem is that my swedturn machine is playing up, ie I do one finish cut 1mm oversize then measure and do a tool offset? Then take a final finish cut at finish size? When I do my first cut the offset could range anywhere from being spot on to half a mill up or down? Then when I change the offset the machine still will not finish size and even if I move the offset to make the job bigger it can still finish it undersize? It's kind of hard to explain? But any help would be much appreciated
    Barry
    Nov 2011
    It's a lathe and fanuc control btw
    Re: X axis problem
    Hi Barry. Do you still have this SWEDTURN lathe?
    Regards
    Dave H.
  1. Z axis problem.
    By hoops1888 in forum Mach Software (ArtSoft software)
    Last Post: 07-02-2013, 07:14 PM
  2. Problem Y-axis
    By moos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2012, 11:07 AM
  3. 4th axis problem
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 12-09-2011, 04:03 PM
  4. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  5. Z Axis Problem - please help
    By topduck in forum Taig Mills / Lathes
    Last Post: 03-17-2010, 04:35 AM
