586,103 active members*
3,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport interact 412 tool changer does not slow b4 tool change
Results 1 to 6 of 6
    Sep 2005
    250
    I have a Bridgeport interact 412 Machine and the tool changer does not slow b4 tool change or when it goes back after a tool change. I have tried adjusting the air cylinder screw with the 2 lock nuts and i have also tried bleed the 2 brass screw
    needle valves that are on top of the air cylinder but it hasn't changed much.
    Any suggestions would be great !!!
    Thanks so much !!
    Sep 2009
    Did you ever find a solution to this? I just bought one of these and am having the same issue just got done trying the same things you did.... no luck.
    Sep 2005
    250
    No luck figuring it out. I have been running the machine the way it is.
    Sep 2009
    I just found out what is causing it, The pneumatic cylinder that makes the tool changer go in and out has a bad cushioning seal on one end of it. The cushioning mechanism provides a pillow of air on either end the stroke since the seal is bad it doesn't create that pillow of air and just leaks around the seal and slams. So that is what the problem is the fix however it's tough I can't find that seal anywhere!
    Sep 2005
    250
    It sounds like we need to get a new pneumatic cylinder. I wonder if they still make them. When i get some time i will look and see if i can find them . If you find one please let me know and i will do the same. Thanks for letting me know.
    Sep 2009
    I just went to my local Parker dealer and had him look for the seal he couldn't find anything. But he did give me a few leads of other stores to try, I am still going to try to find the cushion seal rather than replace the whole cylinder. But if it comes down to it I guess that's what I will have to do. Thanks for the help on this!
  1. Bridgeport Interact 412 Tool Changer Problem
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2012, 03:48 AM
  2. Bridgeport interact 412 tool changer problem
    Last Post: 05-06-2011, 05:18 PM
  3. Slow vertical Z move after tool change...
    By ucdwino in forum Tormach Personal CNC Mill
    Last Post: 11-20-2010, 01:16 AM
  4. Interact 412 - Tool Changer Not Back
    By noremac in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2010, 10:15 PM
  5. Very slow tool change on Tool Room Mill
    By Capt Crunch in forum Haas Mills
    Last Post: 12-21-2007, 07:20 PM
