Ok, so I have been running my 200 for 2 years now, and have had most of the noted issues that others have had no doubt, but I have always had good results and good surface finishes. Lately I have been getting more and more chatter. I have checked and adjusted the gibs and have put a dial indicator on everything. Scary as things do move on this thing, but everything bounces right back to zero. I did notice .002 of runout measured on several different tools and holders as well as the spindle nose itself, all in the same spot relative to the spindle. That seems like a lot. How could this grow assuming it has been fine for 2 years? Also when I push on the spindle from different angles I can move it .004 with maybe 25 lbs of force, but it always goes back to zero, so clearly flex, not movement. Thats as measured at both the spindle itself, and the mill head right above it. For the first time ever, I have had to throw away parts due to severe chatter marks, and it's a part and program I have run hundreds of times. Any thoughts?
