I'm designing a shaft assembly where I have a non-rotating piece (an actuator) that I want to press against a rotating pulley surface. I was going to use a needle thrust bearing between the two, but I realise I'm unsure how to locate the roller cage. Obviously I can locate one thrust washer in the pulley, and the other in the actuator, but I don't know how to keep the roller cage assembly in place. Is it sufficient just to place it under compressive load between the thrust washers while the shaft is rotating, or is something more needed?
Re-reading this I realise my description may not be that clear, but I can't think of a better way to describe it! I've attached a couple of pictures which will hopefully clarify the set up (actuator in orange, needle cage assembly in red, thrust washers in dark grey).
Any suggestions/pointers appreciated!
Luke
