K1325AT / F0808C Series
Technical Parameter:
Model K1325AT/F0808C
X-Y-Z axis working area 1,300 x 2,550 x 300mm
Machine size 2,650x 3,150mm
Resolutions 0.025mm
X-Y movement rack and pinion, gear drive/Taiwan
Z movement ball screw drive/Germany
Guide Linear ¢30 square/Taiwan
Max. speed 60,000mm/min
Max. cutting speed 30,000mm/min
Spindle power 9kw(wind cooling)/Italy HSD
Spindle speed 24,000rpm
Inverter power 11kw
Drive motors Servo/Japan YASKAWA
Working voltage AC380V/50-60Hz, 3-phase
Command code G code
Computer interface USB 2.0
Collet ISO30-12.7mm,6mm,3.175mm
Software Type3 Software/France
Controls SYNTEC/Taiwan
Packing dimensions 2300 x 3350 x 2280mm,2500kgs
Equipment included
A. Oil lubrication system
B. Auto adjusting device
C. Vacuum system
D. Dust collector
