586,983 active members*
3,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Pallet changer problem
    Sep 2009
    Hi everyone,
    I have a problem with my fadal pallet changer on a 96 4020. The clamp pump has stopped working. The oil cup ran low while it was turned off with air connected and the pneumatic pump must have cycled through the night. I took the pump apart and it seems to be able to function fine. When I put the air line on, I use to hear a thumping for about 5 sec while the pneumatic pump locked the pallet into place. Now it does not thump. I am open to suggestions.
    Thank you
    900
    Verify that you have bled all of the air out of the lines. You may just have a pneumatic lock. Also verify that the actuating cylinder is freely operating. Make sure that the relay is functioning to trigger the pump.
    Neal
  1. vf3 ss pallet changer
    By mayhem in forum Haas Mills
    Last Post: 04-25-2011, 10:45 PM
  2. VF3 Pallet Changer Problems
    By j-radkemachine in forum Haas Mills
    Last Post: 03-10-2009, 05:00 PM
  3. Pallet Changer
    By MIDDEN300 in forum CNC Machining Centers
    Last Post: 09-20-2008, 02:32 PM
  4. Pallet Changer for a Fadal
    By Delw in forum Fadal
    Last Post: 05-16-2008, 03:10 PM
  5. VF-3 & Pallet Changer
    By big_mak in forum Haas Mills
    Last Post: 10-12-2007, 08:00 PM
