586,457 active members*
3,374 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > new product- cnc woodworking machine model K45mt-3
    Nov 2011
    61
    K45MT-3 Series
    Technical Parameter:
    Model K45MT-3
    X-Y-Z axis working area 1,300 x 2,500 x 200mm
    Machine size 2,150 x 3,150mm
    Resolutions 0.025mm
    X-Y movement Rack and pinion, gear drive/Taiwan
    Z movement Ball screw drive/Germany
    Guide Linear ¢20 square/Taiwan
    Max. speed 35,000mm/min
    Max. cutting speed 25,000mm/min
    Spindle 1 4.5 kw/wind cooling
    Spindle 1 speed 18,000rpm
    Inverter 1 power 7.5kw
    Spindle 2 4.5 kw/wind cooling
    Spindle 2 speed 18,000rpm
    Inverter 2 power 7.5kw
    Spindle 3 4.5 kw/wind cooling (can use in 90 degree)
    Spindle 3 speed 18,000rpm
    Inverter 3 power 7.5kw
    Drive motors stepper
    Working voltage AC380V/50-60Hz, 3-phase
    Command code G code
    Computer interface USB 2.2
    Collet ER25-12.7mm,6mm,3.175mm
    Software Type3 Software/France
    Controls SYNTEC EMBED_CNC Control System
    Packing dimensions 2260 x 3100 x 1960 mm,1450 kgs
    Equipment available a.Vacuum system
    b.Dust collector
    Attached Thumbnails Attached Thumbnails K45-3.jpg   台湾控制系统.jpg   中间轴垂直工作.jpg   中间轴水平工作.jpg
    Nov 2011
    61
    This is an multi-spindles model, the spindle in the middle can work in 90 degree.
    any comment? ^_^
  1. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2011, 09:54 PM
  2. sell CNC Woodworking Machine,CNC Advertising Machine
    By zhangrui1588 in forum News Announcements
    Last Post: 05-30-2008, 02:43 PM
  3. Trying to come up with a woodworking machine lift
    By LewisCobb in forum Mechanical Calculations/Engineering Design
    Last Post: 05-03-2008, 07:17 PM
