586,419 active members*
3,287 visitors online*
Thread: z return
Results 1 to 9 of 9
    Mar 2011
    29
    z return
    I'm using v2. how do i make the tool retract to the top of a part when i'm contouring? it keeps wanting to rapid through the part.
    Dec 2010
    154
    Quote Originally Posted by Clyde_06 View Post
    V2....?
    Where is your "Z Zero" plane, top of your part or bottom? Are you using the "World Coordinates System" or "Construction View"....?
    Mar 2011
    29
    surfcam velocity 2. my z zero plane is top. and i believe i'm using world. but for some reason it just decided to retract to my z plain. i don't believe i changed anything so i'm not sure why it would have changed.
    Dec 2010
    23
    Could be a couple of things.... There are 2 different planes, one is a Rapid Plane, And the other is a plunge clearance, usually Rapid Plane is set to 1.0 and plunge is .100, if that doesn't help change your rapid plane to Z10. and plunge to Z5.0 and see what happens. also if you are verifying be sure your stock model is correct, should be and 0 and -1.0 in your Z parameters or how ever thick your stock is. If this doesn't help let me know
    Mar 2011
    29
    ok its doing it. this is what i'm seeing and i didn't change anything for the different lines.
    Apr 2003
    637
    I can't tell from your picture what's going on but:
    The rapid Plane will be calculated from Z Zero plane regardless of the geometry picked. So if the material is 2” above the Z Zero and the rapid is set to 1”, you’re going to rapid through the material. Set the Rapid to 3” if the material is 2” above the Z Zero plane for example.
    Under Tools>Options>NC Defaults there is an option to have Surfcam calculate the Rapid plane but I don’t trust it.
    There's a tab on each sequence that controls "feed between" distance. I can't get on the system right now, but it's the far right tab when you have the sequence open of editing.
    The "feed between" distance needs to exceed the distance between retract and plunge passes or the software makes a direct path.
    Apr 2003
    637
    mfgbydesign, you may have something there. Also there is a setting to that will make the feed between plunge, feed or rapid. It’s under 2 Axis Options. I would try resetting this page to the default.
    Mar 2011
    29
    changing the "feed between" worked. thanks for all the help guys!!!
  1. zero return sub
    By rylanrouge in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2011, 02:50 PM
  2. Zero return
    By bubba107 in forum EMCO Mills
    Last Post: 10-22-2009, 01:49 AM
  3. Return to Zero
    By mikemill in forum Machines running Mach Software
    Last Post: 08-25-2009, 08:47 AM
  4. How to fix Zero Return after crash
    By burroughs in forum DNC Problems and Solutions
    Last Post: 03-10-2007, 10:49 AM
  5. Upc Battery & Zero Return
    By Jedi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2007, 03:44 PM
