K45MT-S Series
:cheers:
Technical Parameter:
Model K45MT-S
X-Y-Z axis working area 1,300 x 2,500 x 200mm
Machine size 2,150 x 3,150mm
Resolutions 0.025mm
X-Y movement Rack and pinion, gear drive/Taiwan
Z movement Ball screw drive/Germany
Guide Linear ¢20 square/Taiwan
Max. speed 35,000mm/min
Max. cutting speed 25,000mm/min
Spindle 1 4.5 kw/(wind cooling)
Spindle 1 speed 18,000rpm
Inverter 1 power 7.5kw
Spindle 2 6 kw/wind cooling (can use in 90 degree)
Spindle 2 speed 18,000rpm
Inverter 2 power 11kw
Drive motors stepper
Working voltage AC380V/50-60Hz, 3-phase
Command code G code
Computer interface USB 2.2
Collet ER25-12.7mm,6mm,3.175mm
Software Type3 Software/France
Controls DSP0501 For Two Spindle
Packing dimensions 2260 x 3100 x 1960 mm,1450 kgs
Equipment included
A. Oil lubrication system
B. Auto adjusting device
Equipment available
A. Vacuum system
B. Dust collector
Please feel free to contact me.:idea:
Any question will be much appreciated.
Thanks.
--Bella
