586,744 active members*
5,756 visitors online*
Results 1 to 6 of 6
    Jun 2011
    Machining alluminium
    Hello,
    I'm having problems with my end mills getting "clogged" on alluminium then the finish is poor.
    I'm using a 3mm 4 flute carbide end mill at 3500rpm's. Using a feed rate of 60mm per minute, taking a 0.5mm cut with flood coolant.
    The cutters were from here, i'm not sure if you can get an alluminium specific which is less likely to clog, or change the feed/speed
    7LEADERS 2MM SOLID CARBIDE END MILL (E114F) TiALN NEW | eBay
    Any suggestions?
    Apr 2011
    132
    use a 2 flut endmill
    Jun 2011
    Quote Originally Posted by WATERJET71 View Post
    Will try that, is there any way to make my current cutters work? I've got lots of 4 flute end mills.
    Oct 2008
    78
    Three problems, the cutters are coated (uncoated would be much better for aluminium), too many flutes, and the feedrate is not high enough.
    Try upping the feedrate to about 250mm / min.
    At 60mm / min a four flute cutter is kind of friction welding its way through aluminium.
    You need to make a big enough chip with each flute so that the coated cutter can actually take a scoop of metal away instead of rubbing, but not so big that the chip jams up in the flute.
    Jun 2011
    Quote Originally Posted by dblox View Post
    Hello,
    Thanks for your reply.
    Thats interesting to know about coated, i'll try and save these cutters for steel then.
    I didn't realise you could go "too slow" I didn't dare go that fast for fear of snapping the tool or wearing it out very quickly.
    While i'll probably reserve these cutters for steel i'll also try a faster speed rate on the next ones.
    Thanks again for your help.
    Jul 2005
    12177
    TiAlN coated tools have a coating that is partly aluminum oxide, that is the Al part of the name. Using these cutters for aluminum is not successful because the aluminum oxide coating tends to stick to aluminum not allow the chip to slide past. Not even flood coolant can overcome this stickiness and if you try using these cutters on aluminum at high rpms on a big machine you get a smoking, steaming blob of metal spinning round.
  1. Machining Fixture Designer w/machining background - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:53 PM
  2. Alluminium engraving????
    By contour in forum MetalWork Discussion
    Last Post: 05-12-2009, 06:49 PM
  3. deep drawing alluminium
    By cob in forum Vacuum forming, Thermoforming etc
    Last Post: 04-21-2009, 06:21 AM
  4. MIS CNC Machining and tooling - General machining - Thermoform Molds
    By modernprecision in forum Employment Opportunity
    Last Post: 11-24-2007, 05:05 AM
  5. Machining anodized parts or anodize after machining?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-12-2006, 06:22 AM
