Hello all, I have a problem with my servo and hope someone can help me. First of all let me introduce my system. I use Mach3 with DSPMC/IP motion controller and servo drive (sidc650) with motor (sia751). I have setup my drives in velocity control mode because I can get better resaults from it and it is more stable. Now on to the problem. When I turn on the power and want to move any of the axis for a few milimeters motor accelerates slowly with constant speed. But when I move axis longer than few milimeters motor jumps hard and then everything is working normal. All motors are working well without any problem. This problem appears on every axis (x,y,z) every time drives are powered ON/OFF. If I set drives in torque mode, motors start to spin withaut any problems even if drives are turn on/off. I just can't figure out what is causing that problem. Also I'm attaching pdf manual of drives and I made some videos about this problem.
[ame=http://www.youtube.com/watch?v=Mhr8beADhjU]1.AVI - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=fmQ71kvrvU4]2.AVI - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=TONOXsU1els]3.AVI - YouTube[/ame]
Here are my curent settings for y axis
PN01 0002 (velocity control mode)
PN08 0000
PN10 1500
PN11 1000 MAX acceleration
PN15 -5
PN16 5
PN17 32 SPEED SCALE
PN20 60000
PN25 2000 FOLLOW ERROR
PN30 P 1000
PN31 D 000
PN32 I 000
PN33 00 DAMPER
PN35 720 Forward velocity compensation
Regards,
Peter
