586,115 active members*
3,476 visitors online*
Results 1 to 9 of 9
    May 2006
    50
    PMDX-122...which THC?
    I have my DIY plasma cutting system. I've been cutting for more than a year, but I always find the problem when the sheet metal is wrapped. So I decided to upgrade to a THC system. My problem is I don't know for sure which THC to use, so I can keep using the existing BOB PMDX-122.
    Any advice, experience is welcome.
    Rick
    Sep 2009
    THC options
    I`m in the same situation.
    You can choose from Cand, Proma and Agelkom.
    Another MM`er is mounting an Agelcom device, I chose Proma, so we can compare future experiences. Proma seems to me a very simple system to control your height setting up the desired voltage parameter. We will see!?
    Cand sells only two Set`s, so it up to you.
    May 2006
    50
    Quote Originally Posted by claudiu View Post
    I chose candcnc but my plasma machine doesn't work very much with the candcnc hardware.
    Aug 2007
    215
    if you use a powermax cutter this may be another option to those already mentioned.
    Sep 2005
    1195
    wow so expensive! is that stand alone?
    Sep 2005
    1195
    Maybe you should contact Torchead candcnc and ask what to do.
    Aug 2007
    215
    Quote Originally Posted by asuratman View Post
    wow so expensive!
    Huh???? how do you figure that out?
    Sep 2005
    1195
    I did not know exchange rate, then I found it cheap after I read forex. Sorry.
    Aug 2007
    215
    shame you didn't checkout exchange rates BEFORE you dissed it. It's hard enough making a living these days as it is.....(nuts)
  1. G203V and PMDX 134
    By swaggs21 in forum Gecko Drives
    Last Post: 04-19-2011, 03:26 AM
  2. PMDX-125 or PMDX-132 for Geckos?
    By Nivea in forum Gecko Drives
    Last Post: 03-24-2010, 08:18 AM
  3. PMDX-122 and Mach3
    By ranchak in forum Mach Mill
    Last Post: 01-23-2010, 09:56 PM
  4. GECKO W/202 AND PMDX 131
    By glengen3 in forum Gecko Drives
    Last Post: 05-04-2008, 11:00 PM
  5. Mach3 + PMDX-122
    By Burn in forum Mach Software (ArtSoft software)
    Last Post: 01-06-2008, 09:33 PM
