586,112 active members*
3,081 visitors online*
Results 1 to 7 of 7
    Nov 2011
    XY Interpolation on Mill/Turn
    I`m trying to make an operation about XY interpolation on Mill/Turn. The problem is, the SolidCAM considers only the side of Z+. How can I perform that operation in the opposite side, that is, on the Z- side?
    Nov 2011
    Normally we just change all the z-point by key in , or open your programming with cimco edit , that is easy for you to replace all your Z+ become Z- by using (mode REPLACE)!!! Hope i am not talking nonsense here............ Sorry if i miss understanding here!!!
    Nov 2011
    Interpolation XY on the opposite side
    Hellow,
    Thanks for the reply, but the problem is other. Observing that the plane XY has two sides, Solidcam just considers the side of Z+ direction for milling, in that case.
    As I want to mill on the opposite side, that is, Z- direction, how can I to do that in Solidcam?
    Attached Files Attached Files
    Oct 2011
    I guess I must be misunderstanding as well because whether or not you are on z+ or z- your x and y axis stay the same.
    Make your part in the software you have and then flip your z numbers in the post accordingly as mentioned. If it is an odd shape you are milling and orientation is key, you may have to cam it out backwards.
    Nov 2011
    No. =(
    maybe this example shows that I want. How I do that operation of pocket...
    Oct 2011
    I still fail to see your issue, but how about translating your part so the face visible in your drawing is z0 rather than a positive value.
    If your cam software only registers one side of your z axis then you will have to play around within those confines and modify your post accordingly.
    Jul 2011
    It's necessary create a new position on the opposite side for working that (Y)
  1. nx5 how to turn off circular interpolation
    By boofa in forum Uncategorised CAM Discussion
    Last Post: 05-27-2008, 08:03 PM
  2. Mazak Mill Circular Interpolation problem
    By DublJ in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2007, 06:13 PM
  3. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  4. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
  5. Fagor 8055 Mill Sample Code and Helical Interpolation
    By sailcam in forum G-Code Programing
    Last Post: 10-12-2006, 12:37 PM
