586,337 active members*
4,053 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18t weird tool offsets, Hwacheon lathe
Results 1 to 11 of 11
    Feb 2011
    8
    Hey guys I've been searching with no results...
    I've been running a differant lathe the last few days and I'm pulling my hair out with these tool offsets..
    If I call a tool up in MDI ex. T0101 nothing changes on my postion screen. I can call any tool up in MDI and the postion numbers are all the same, relative, absolute, and machine. But in a program the absolute shows the correct offsets.
    I can call up T0101 bring it down in the x and touch off on a piece of 2.00 diameter stock. Then in the tool offset screen hit X2.00 measure. My tool should be set right? Leaving the machine as is I then call it up in MDI and the number displayed is way off from 2.00 Its the same deal if I use the tool setter probe.
    Could it be reset button not canceling offsets,etc...?
    I've ran several other 18 series controllers that didnt do this. I'm sure theres a parameter for this somewhere?? Any help would be greatly appreciated.
    Aug 2011
    2517
    on the workshift page in all of the X positions there should be a 0
    if it is zero post some pics of your offset/workshift screen maybe that will give us more info
    or exactly how much is the position out of position?
    also what is the number in parameters 5015/5016/5017/5018? they are reference numbers that relate to the calibration of the setting arm in relation to your machine zero.
    and what do you have in 5002, 5003, 5004
    Feb 2006
    1792
    Quote Originally Posted by mcshaner2k View Post
    If I call a tool up in MDI ex. T0101 nothing changes on my postion screen. .
    5003#6 (LVC) = 0 (offset not cleared by reset)
    5003#6 (LVC) = 1 (cleared by reset)
    Aug 2011
    2517
    LVC is not relevant here. reset is not pressed.
    did you type it correctly?
    G0 T0101 then press EOB then press INSERT then press START
    the readout in Absolute Position should change.....
    Feb 2011
    8
    Let me try to clarify better.
    When I call a tool in mdi it wont show the tool offset on the display page. In auto mode running a program it shows the tool offset in absoule as it should.
    When calling a tool in mdi the display reads the same numbers for machine relative amd absolute.
    5002. 01010000
    5003. 11000000
    5004. 00000000
    Hope this helps!
    Aug 2011
    2517
    not sure where your problem is but my numbers for those parameters are.....
    5002 10000010
    5003 11000000
    5004 00001000
    what have you got at 3115 and 3290?
    Feb 2011
    8
    Thanks for the reply!
    I'm home now but tomorrow morning ill try plugging in your numbers for 5002,5003, and 5004 to see what happens..
    Ill get back to you with 3115 and 3290.
    Aug 2011
    2517
    ok compare these at the same time.
    My numbers are....
    3115 Axis1 00000000 Axis2 00000000 Axis3 00000001 (X,Z, turret servo)
    3290 10010000
    Feb 2006
    1792
    After executing T0101, does the screen show T 101 at the bottom of the screen?
    The MDI program should only have T0101, no M30 in the end.
    I guess you are talking with reference to G54.
    Feb 2011
    8
    Thank you so much!!!
    After plugging in those numbers for 5002 5003 and 5004 my display is working properly now as it should.
    For some reason my tool setter probe wont work in the x minus. I can push all the buttons with my fingers and watch my offset change except for the x minus button which does nothing. Don't know if this is related or not..
    Aug 2011
    2517
    check parameters 5015/5016/5017/5018. they are reference numbers that relate to the calibration of the setting arm in relation to your machine zero. if you push the X- switch and nothing happens most likely the switch is bad.
  1. Lathe Tool Offsets How To?
    By Cartierusm in forum MetalWork Discussion
    Last Post: 06-24-2018, 03:19 AM
  2. CNC lathe tool and work offsets
    By mm4039 in forum MetalWork Discussion
    Last Post: 11-18-2013, 06:28 PM
  3. Origin and tool offsets Lathe
    By Bony Fingers in forum Daewoo/Doosan
    Last Post: 04-15-2009, 06:36 AM
  4. CNC Lathe Tool Offsets, just a few questions...
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 03-16-2009, 05:21 PM
  5. 12L FANUC 10T TOOL OFFSETS
    By cwh in forum Daewoo/Doosan
    Last Post: 11-20-2008, 07:10 PM
